Home > Maintenance & Mods (L405) > L405 Active Roll bar system replacement (water and corroded)
CapriV8power
United Kingdom 2014 Range Rover Autobiography SDV8 Carpathian Grey
Eye watering quote for the work from Land Rover, but I fancy attempting the work myself with a mate.
Land Rover says its all corroded and has evidence of water in the system. I can see all the cheap pipework is corroded so have ordered everything front to back. But I don't plan to replace the Roll bars, pumps or valve levelling components.
From looking underneath its likely I need to remove exhaust and fuel tank which looks easy enough but do we need to also remove the rear subframe which would be awkward / time consuming?
Before we start I will flush the system to clear the water - I know its likely that a small amount will remain but I am saving £7K on parts and labour!
any advice/pictures/links of similar jobs would be appreciated
Post #622326 3rd Feb 2022 10:27am
Mikey
Rear subframe needs removing to replace rear pipework
Post #622334 3rd Feb 2022 12:46pm
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
wow never realised this was such a big and pricey job
Post #633122 28th May 2022 8:24am
knwatkins
Take a look at these videos...
 Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #633129 28th May 2022 12:30pm
Mikey
Those videos are making my OCD twitch Embarassed
Post #633131 28th May 2022 1:07pm
mpirie
They're making my wallet throb! Big Cry
Mike
Post #633144 28th May 2022 7:36pm
Gremlin500
So glad I have the TDV6 without this feature.
If it’s not there, it can’t fail.
The complete lack of JLR’s attention to underbody corrosion prevention is incredulous in this day and age. Shocked Shocked Shocked “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #633152 28th May 2022 10:13pm
CapriV8power
The fatter one is me (Sam) Rolling with laughter Glad you found the video's - we decided to record the work to help anyone else out. We would certainly do it again and found many short cuts along the way should you want some advice?
Was an epic amount of work if you are attempting this with no knowledge of how the car is layed out. The manuals we found online were a help.
Land Rover were obviously trying to escape doing the job or just replace everything as they like clean parts...
Post #633243 30th May 2022 12:42pm
Mikey
I'm intrigued as to how you removed the rear prop at the diff end. We didn't see that bit Whistle
Not a huge issue at my end, as we've the correct special tools to remove and refit, but its not something for the amatuer/DIY mechanic
Post #633269 30th May 2022 5:26pm
CapriV8power
One of us is slightly more than DIY (not me obviously).
We had the appropriate 'special tool'. The socket is not that uncommon.
Post #633306 31st May 2022 7:25am
wealy
My car has this leak from the corroded pipes just above the left rear silencer. It started as a small drip and now it’s much worse. If I simply leave it and the active system ceases to work, will it do any damage further down the line? The V6 doesn’t have the active system so I guess the car will handle differently but I guess I would have to live with that. Any suggestions.
Post #638468 2nd Aug 2022 7:19am
mpirie
Mine's just been returned after having the front pipes replaced.
Apart from the mess the leak makes, if air gets into the system, you start to get clunking noises when the steering is turned.
My corrosion was at the front offside clamp for the pipes.
Steel pipes, salty roads? C'mon Land Rover! Censored
Mike
Post #638469 2nd Aug 2022 7:29am
knwatkins
If you loose all of your fluid and continue to drive it, the pump will quickly burn out, that's for sure. You'll also have various warning lights and messages permanently displayed on the dash. My recommendation would be to fix it. Kev
Post #638477 2nd Aug 2022 8:57am
Seatown
Scotland 2013 Range Rover Vogue SE SDV8 Firenze Red
Mike
Maybe Land Rover should introduce a special 'Scottish Roads' heavy duty edition or at least put it on the options list. Trouble is they'd likely make it a software enabled feature rather than beefing up the hardware!
It'll be interesting to see what impact highly corrosive British salty roads have on the unseen parts of electric vehicles over the next few years.
Post #638482 2nd Aug 2022 9:13am
Mikey
And when that happens, the pump puts metal fragments through the rest of the system, and damages the valve block
Post #638547 2nd Aug 2022 8:32pm
