Home > Technical (L322) > Rear bush removal tools
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Guys, will be replacing my rear bushes soon, anyone have any recommendations for the tools required to press them out and back in again? Christian.
Current Cars
2011 Range Rover Vogue SE
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #622275 2nd Feb 2022 10:38pm
Discotigger
Either a good hydraulic press or you could make up a 'bush removal tool' ALA Edd China on Wheeler Dealers. This seems to consist of some oversize sockets, oversize washers, some threaded bar with corresponding nuts and a bit of 'elbow grease'.
I'm getting all my suspension arm and anti-roll bar bushes swapped out for poly bushes by my local indy mechanic, as an experiment/challenge, just to see what the end effect is. The ride on my 2012 4.4TDV8 Westie isn't the best, so thought I'd take the plunge and see what would happen if I went 'all poly bush'. I'll be starting a thread in the next couple of weeks to report on my findings once the swap has been completed. Read though a couple of old threads on here about other owners experiences, but thought I'd take the chance, as poly bush technology has moved on quite a bit from the 'olden days'.
Post #622284 2nd Feb 2022 11:00pm
johnboyairey
I did mine 20 mins each side, I used this kit. £25 perfect fit. (l322 upper rear bushes)
when you fit the new bush look for the slightly chamfered edge, on one side, this is the leading edge. it will go in easier. (with a little oil wiped on too)
https://www.ebay.co.uk/itm/254877553459
Post #622291 2nd Feb 2022 11:33pm
Ffrr-lover
I used a kit like this for my rear bushes, along with an impact driver. I would recommend a decent ratchet and extension bar for this job…
https://www.ebay.co.uk/itm/Universal-Press...635-2958-0
Plus lots of normfest freeze spray to help crack the rust!
https://www.eurocarparts.com/p/normfest-su...OR28944421
And I followed the excellent guide by Joe90 in the wiki…
https://www.fullfatrr.com/forum/viewtopic....066a64f102 Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #622307 3rd Feb 2022 8:11am
Caesium
Thanks for that link, this is much more palatable than spending £80 on a tool I will probably only use once. I'd rather buy some more spares for the RR Laughing
I've already got a set of seal drivers, a fuel pressure gauge set, a set of helicoils that I have only ever used once, I seem to be collecting tools that only get one use.
I was considering some old sockets but it's hard to know what size.
I think I'll just buy the 25 quid one for now and see how I get on when my bushes arrive. Christian.
Current Cars
2019 BMW X4
or
Post #622312 3rd Feb 2022 9:28am
