Home > Technical (L322) > L322 Air Suspension compressor replacement? |
gm0rdi Member Since: 19 Jan 2022 Location: Hawick Posts: 15 |
Greetings
31st Jan 2022 5:29pm |
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 451 |
As said before, the OE compressors are actually pretty good quality and if you are mechanically minded (which is pretty much a pre-requisite to owning an LR product) then once you get it apart you'll see why.
3rd Feb 2022 9:25am |
Well, I am grateful for the two gentlemen who took the time and trouble to respond - thank you both. I have a resolution, and the answer was "none of the above". However, your responses DID shore up my determination to get to the bottom of the issue without being bled dry by a main stealer
6th Feb 2022 6:16am |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 788 |
Thanks for the answer to your problem, its always good to hear of a positive outcome. 2 of those connectors and a roll of the 6mm pipe live in my emergency kit and have been there since my p38a days. 2007 TDV8 VSE
6th Feb 2022 9:19am |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1188 |
First off, I wish I could write clearly and logically like you mate, very clear.
6th Feb 2022 12:19pm |
Hello Kev.
7th Feb 2022 5:13am |
Glad you got it sorted mate. |
7th Feb 2022 8:20am |
I've had a good look through the workshop manual and it does not show any couplers on the main line from the compressor to the reservoir valve block, or from the reservoir valve block to the reservoir itself.
7th Feb 2022 11:59am |
