Home > In Car Electronics (L322) > how to turn off/disable 'traffic news'. 2012 l322, please.
johnboyairey
guys... I have the 2012 L322 Westminster, (with logic 7 if its relevant). I can't switch off 'interrupting traffic news', from all sources. (ie, the local radio channel interrupts a cd/iPod etc, with traffic news, which I can then override by hitting A/V button)
If I go into each source, and go, 'settings' and try and 'clear all' announcements... it still interrupts, and if I select one/some/ all options, 'enable' and then 'clear' them, it still interrupts every 15 mins or so, with local traffic news. other (lesser!) cars, just have a TA button...(on/off) I can't find that... unless i'm not 'seeing it'.
am I going mad.... is it mandatory to have traffic news on all the time?
when you're cruising with Classic FM, and the 'good bit' comes... it cuts in, often booming loud too! because I've got the music up loud! -drives me mad!
Post #622276 2nd Feb 2022 10:41pm
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
Just been out to the car (2012) to check....
The 'Info' button under the volume control toggles the T/A On/Off.
You're welcome! Wink The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #622277 2nd Feb 2022 10:48pm
mjdronfield
According to this, it’s not in any setting option, it’s the INFO button under the volume knob….
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #622279 2nd Feb 2022 10:52pm
mjdronfield
Ah, my old doddery typing fingers not fast enough Rolling with laughter 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #622280 2nd Feb 2022 10:53pm
johnboyairey
YES!... just been out, and you're right, I pressed till it's now 'off'. I will try it at weekend.... thanks.
-I knew it was something so simple...
Thank you!
Post #622281 2nd Feb 2022 10:54pm
JMC
You snooze, you lose!! Whistle Laughing The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #622287 2nd Feb 2022 11:05pm
Ffrr-lover
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
You could always do what I do?
After disconnecting the battery for the umpteenth time, just give up tuning the radio in anymore. I have lots of static stations “tuned” in so no chance if this happening to me Laughing Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #622308 3rd Feb 2022 8:17am
JayGee
You need to go into the RDS section of the FM tuner to disable it as it's an FM broadcast that cuts into other sources. 2012 TDV8 Vogue (L322)
Post #622410 4th Feb 2022 10:16am
