Home > In Car Electronics (L322) > Bovee streaming won't restart after phone use
JayGee
Iphone 13 pro connected to Bovee and car. When I take or make a call the bovee won't reconnect and shows device error and the only way to resume streaming is to unplug it and plug it in again. Anyone else finding this problem? 2012 TDV8 Vogue (L322)
Post #620770 21st Jan 2022 1:00pm
tpeat12
United Kingdom 2003 Range Rover Vogue Td6 Epsom Green
Yes I have the same issue. It doesn’t seem to happen provided the iPhone is connected to the Bovee and to the built in L322 Bluetooth used for calls
Post #620999 22nd Jan 2022 8:08pm
JayGee
It is setup with dual Bluetooth connectivity- Bovee1000 + Landrover 2012 TDV8 Vogue (L322)
Post #621046 23rd Jan 2022 8:50am
Stuart-
I have the same issue with mine. I just assumed it was a bug and live with it. 2017 4.4 SDV8 Autobiography in black
2018 D300 SE Velar in champagne
1982 Rolls Royce Silver Spirit in green
Spiffing wheel centre caps, L322 sill repair panels, etc
Post #621092 23rd Jan 2022 2:00pm
JayGee
Moved the Bovee to the trim strip next to the seat and removed the locking tabs on the connector and routed the cable back to under the large storage unit. This way when it cuts out I can just easily pull the cable out and in again to reset it. 2012 TDV8 Vogue (L322)
Post #621807 29th Jan 2022 5:33pm
