Home > Technical (L322) > MAP sensor....caused limp mode. |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2501 |
A should be the on the RH bank when looking from behind the engine, not from in front. If you disconnect the electrical connector you should get a permanent fault on that sensor, then swapping the sensors left to right the fault should swap sides if the sensor is indeed the cause.
28th Jan 2022 7:44pm |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 330 |
I replaced mine a while ago on a 2012 4.4TDV8 (while eliminating them as a cause of something), I have 2 spares which work perfectly because there was no change whatsoever when I replaced them.
29th Jan 2022 12:10am |
Tiprat Member Since: 05 Aug 2021 Location: Manchester Posts: 92 |
Thanks for that GraemeS it has been spray cleaned before, approx 5 months ago, previous owner warned me in advance of the issue. I shall look at it again, if memory serves me right, the thin wire was touching the plastic that runs along the side of it.
29th Jan 2022 8:09am |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 |
I’m interested in one of those!
29th Jan 2022 8:37am |
