![]() | Home > Maintenance & Mods (L322) > Diff oil |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1899 ![]() ![]() ![]() |
According to the workshop manual... 75W-90. The rear Diff take 1.2 ltr ( stated in the workshop manual - even wet refill) and the front takes 0.75 ltr.(again wet refill). If you want to keep the car along time change the Diff Olis. It is very easy to do if you have the correct pump system.
Suggs Member Since: 16 Jul 2015 Location: Norfolk Posts: 94 ![]() ![]() ![]() |
Thanks luckily the gearbox has been fine after adding some dr Tranny fluid but im about to change its oil and filter now, decided a good idea to do the diffs as well while in the garage. will order up some 75-90 |
Thats good to know.
worth trying the Dr Tranny as it seems to help, mine was only a very slight vibration and it stopped it instantly. Its cheap so you might as well give it a try.. |
