![]() | Home > Maintenance & Mods (L405) > Choice of oil for sdv8 |
Landphil Member Since: 03 Oct 2016 Location: U.K. Posts: 119 ![]() ![]() |
If the Petronas oil is a Fully Synthetic Engine Oil and says it is ACEA C1 Low SAPS Ford WSS-M2C934 then you can safely use it. If it doesn’t you shouldn’t use it. |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 774 ![]() ![]() ![]() |
As above. If it meets the spec, it'll be fine. Kev
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3820 ![]() ![]() ![]() |
Opie oils include it in their options for the 4.4 tdV8, but are showing it out of stock.
154JON Member Since: 31 Mar 2019 Location: Essex Posts: 131 ![]() ![]() ![]() |
Morning
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1368 ![]() ![]() |
If it meets the specifications required it doesn't matter what name is on the label, thats just preference or marketing... |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
I use Morris of Shrewsbury's version that meets the spec |
Just ordered 20ltrs from Smith and Allan on Kev Watkins recommendation. |
I've been using S&A for a few years. Good stuff, meets the spec and great value |
