![]() | Home > Technical (L405) > Is it just me or does the pre-heat just not really work well |
Martin2 Member Since: 15 Jun 2020 Location: Northamptonshire Posts: 784 ![]() ![]() |
Do you have the FBH as an option or is it just remote start? The engine will take an age to warm up with remote start, with the FBH it much quicker, 10-15 mins before you leave the house depending on how cold it is. MY23 Panamera E-Hybrid
ilard Member Since: 21 Oct 2012 Location: London Posts: 712 ![]() ![]() |
Obv mines petrol, but I find the remote FBH warm up is great. No extraordinary heating required.
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 793 ![]() ![]() ![]() |
We have this problem too and I even asked the dealer to check the system. There was a HEVAC software update that improved the things a little but, compared to the previous L322, it certainly is a step down. We also own an I-Pace, which has basically the same system and I know the cabin is smaller, but the fan spins much faster on auto (on balanced setting) and therefore no adjustment is required to heat the interior when entering... Also, the seat heating is much more powerful, I know the seats are a different size, but the fans seem to turn on higher speeds there too... Is it a deliberate decision for cabin quietness, I wonder, because, if you put the climate on fast & powerful in the Range Rover, it is greatly improved, but of course with higher noise... So, besides setting (in the climate menu) the blower to high and checking if the pollen filter is clean, there is really not much else you can do... |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
The FBH on our MY16 4.4 does the trick nicely, equally as good as the old L322 I would probably say.
Yes, if you use the app to heat rather than the remote or set the depart time in the car, then it remote starts the engine rather than uses the FBH. MY23 Panamera E-Hybrid
There is no FBH in the P400e... Only electric preheat while connected to charging... At least not in ours and it wasn't an option either... |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1661 ![]() ![]() ![]() |
MY14 No major issues here - FBH works really well and seat heating is rapid.
Feels like a backwards step to me that, we always start the FBH with the App. I wonder why they changed it? Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8 Previously George a 2007 MY07 Java Black VSE 3.6 TDV8 Previously a 04 MY04 Defender 90 ![]() |
My 15MY FBH using the remote works brilliantly... |
CUE99T Member Since: 02 Oct 2011 Location: Glasgow Posts: 779 ![]() ![]() |
Sorry was offline for a bit.... I don't have the FBH as far as I know ..... I just use the Mobile App to start it .... Also how do I change the blower setting of "Hi" to have blowers at 7 NOT 2? It's doing my head in!! all smug in my new plug! 2021 Westminster Black D300 2013 Vogue SE - gone Some Porsche Cayenne guff pretending to be a 4x4!! 2006 Vogue 2004 Vogue 2001 Vogue |
Thats really assuring I'm not alone.....disappointing isnt it.....my old VSE was roasting on heating but had no pre-heat but the Evoque seemed to be much better but again smaller cabin..... And sadly this is why People buy Porsche or Mercedes...... all smug in my new plug! 2021 Westminster Black D300 2013 Vogue SE - gone Some Porsche Cayenne guff pretending to be a 4x4!! 2006 Vogue 2004 Vogue 2001 Vogue |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1261 ![]() ![]() |
Is it not the case that with the higher Euro emissions etc it means that the newer cars dont exhaust by the wheel arch anymore.
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 ![]() ![]() ![]() |
Compared to my L322, the FBH on my current FF is pitiful.
Even with the worst frost, ours is usually clear in 5-10 minutes via the FBH remote started via the App so that doesnt sound right at all |
