Home > Maintenance & Mods (L322) > 2011 4.4 TDV8 Alternator charge volts ? |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3252 |
Should be around 14.5v unloaded ( no lights, heated seats etc) - sounds like it needs replacing. 2012 TDV8 Vogue (L322) |
22nd Jan 2022 12:08pm |
Ttrees Member Since: 08 Jan 2022 Location: Lincolnshire Posts: 13 |
Thanks thats what i was expecting but i know these smart alternators charge at different rates |
22nd Jan 2022 12:16pm |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 455 |
The main noticeable difference is they take longer to kick in from startup.
22nd Jan 2022 10:10pm |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 809 |
I see mine vary from 13.8 up to 14.9v
22nd Jan 2022 11:26pm |
Thanks
23rd Jan 2022 9:54am |
Worth doing the water pump while you are at it. 2012 TDV8 Vogue (L322) |
23rd Jan 2022 9:56am |
I know i will have most of the work done to get to the pump but are they prone to fail then ? |
23rd Jan 2022 9:59am |
No more prone than any other waterpump but they are not that expensive and why risk it? 2012 TDV8 Vogue (L322) |
23rd Jan 2022 10:05am |
Ok thanks i will have a look |
23rd Jan 2022 10:07am |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 |
I’d personally say it’s best to do it. Stripping down to be able to replace the alternator is a pita job so not having to do it more than once (or twice in your case) makes it worth the expense.
23rd Jan 2022 1:05pm |
I get what you are saying although there is not much to go wrong with them except the bearings ill see if i can get it striped to the point of having a good look at the pump to see if its running nice and smooth then if needed i can get one before next weekend when i will be fitting the new alt belts and puleys.
23rd Jan 2022 3:31pm |
ffrr14 Member Since: 21 Apr 2021 Location: Sydney Posts: 187 |
Is that a water pump? SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC New Toy: Unimog U1550L/37 New : G350D |
26th Jan 2022 9:56pm |
briangunn Member Since: 19 May 2019 Location: London Posts: 56 |
My 112k (at the time) 3.6TDV8 water pump wasn't leaking, but there was fairly significant play in the bearings, so I used the opportunity whilst everything was apart to replace it. Also did all of the aux belt tensioner pullies as they had play and noise.. |
26th Jan 2022 10:24pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2494 |
Water pump bearings eventually fail which leads to the seal leaking. My 4.4's alternator has just failed at 150K Kms so I'll replace the water pump as well as all the idlers and tensioner to avoid any of them failing which could leave me stranded. |
27th Jan 2022 12:00am |
