![]() | Home > General (L405) > tdv6 vs tdv8 |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3817 ![]() ![]() ![]() |
I have pinched this screenshot from Facebook of the local independent garage that I use.
Mike. G reg 2.5VM Vogue Portofino red 1991- 1999 V reg 2.5td P38 Rioja red 1999- 2006 53 reg td6 Vogue Oslo blue 2006- 2015 11 reg 4.4 TdV8 Vogue SE. Baltic blue 2015- date. https://www.fullfatrr.com/forum/topic56162...tty+affair |
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 527 ![]() ![]() ![]() |
When I was in Disco world, my D4 was an amazing example.
There are not lots of posted failures of the 3.0 TDv6 engine in the L405, based on this forum at least - and my understanding is this is the best L405 and L322 forum in the world. There are some (not lots) of examples and there are also some strong examples of the affected owners getting the car fixed FOC via LR/ under a warranty. There is also a theory that if the car is well maintained and serviced and correct oils are used, there is even less to be worried about, if indeed there is anything to worry about (5th year of owning a L405 TDv6 and it’s superb). There are also examples of big things going wrong with the 4.4 TDV8 L405, just as every make and marque of vehicle can encounter problems 👍🏻
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3218 ![]() ![]() ![]() |
the 3.0L also doesn't have the active cornering suspension which the 4.4 does. |
Martin2 Member Since: 15 Jun 2020 Location: Northamptonshire Posts: 800 ![]() ![]() |
Both have self levelling air suspension, but the V8 has active roll control. Some people aren't bothered about not having it, but I drove both straight after each other and it was a must. But just my opinion MY23 Panamera E-Hybrid
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
I can second the drive back to back approach, I did that and the 4.4 was the clear winner for me personally. Have to say the 3.0 didn’t worry me, there doesn’t seem to be so many folk reporting it on the L405 compared to heading over to the Disco forums. Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
West Yorks V8 Member Since: 25 May 2020 Location: West Yorkshire Posts: 43 ![]() ![]() |
Hi all
Test drove a 4.4 then a 3.0 back to back because wanted a 4.4 but was doing the try them all thing… and went for the 3.0 because? the car we ended up buying was better spec’d, nicer and in much better condition than the 4.4 and was great to drive anyway… |
CMJ Member Since: 10 Oct 2010 Location: Lancashire Posts: 208 ![]() ![]() |
Having had both this is the thing for me. On the flip side I average 34mpg in my tdv6 vs 26 in my 4.4 4..4 also has bigger brakes and better stopping. Flip side. Brakes are quite a bit cheaper for tdv6. 2013 L405 AB 4.4SDV8 Luxor/Ivory, 2007 Vogue TDV8 Epson Green/Sand, 2008 Vogue TDV8 Buckingham Blue/Sand, 2003 Vogue 4.4 LPG Epsom Green/Sage, 1998 Vogue SE 4.6 LPG Epsom Green/Cream |
SS.Lyria Member Since: 01 Dec 2016 Location: London Posts: 263 ![]() ![]() ![]() |
Can only speak of D4 ownership.
