Home > Technical (L405) > Rear door child locks?
jumpin mouse
United Kingdom 2015 Range Rover Autobiography SDV8 Aruba
My MY2016 SDV8 AB both rear doors now cannot be opened from the inside, this is something new as it worked fine for the last few years.
I haven't changed anything, any ideas anyone please?
Post #620865 21st Jan 2022 10:59pm
CMJ
2015 Range Rover Autobiography TDV6 Santorini Black
Check you have not activated the rear window lock switch on the drivers door that also activates the electronic child locks. 2013 L405 AB 4.4SDV8 Luxor/Ivory, 2007 Vogue TDV8 Epson Green/Sand, 2008 Vogue TDV8 Buckingham Blue/Sand, 2003 Vogue 4.4 LPG Epsom Green/Sage, 1998 Vogue SE 4.6 LPG Epsom Green/Cream
Post #620866 21st Jan 2022 11:08pm
scotsjon
United Kingdom 2016 Range Rover Autobiography SDV8 Farallon Black
As above, that’s what I did, took me an age to figure bit out 🥴
Post #620869 22nd Jan 2022 12:25am
scotsjon
As above, that’s what I did, took me an age to figure it out 🥴
Post #620870 22nd Jan 2022 12:25am
Bora20
Canada 2013 Range Rover 5.0 SC V8 Santorini Black
My right rear doesn’t open at times. Child lock defaults to on which is incorrect.
Cycling the child lock button on the drivers door will open it. I have ordered a used replacement door latch assembly to rectify the problem. Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #620985 22nd Jan 2022 7:12pm
jumpin mouse
Yes, rear window door locks had been activated. I thought that was only for the windows but obviously not.
Thanks everyone. Forum to the rescue, again.
Post #621000 22nd Jan 2022 9:20pm
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
Every day's a schooldays with a 405. First time we had freinds in the back the child locks were on. Quick ref to the handbook and all sorted by the drivers door controls. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #621035 23rd Jan 2022 8:14am
