Home > Technical (L322) > Engine swap in Northamptonshire |
PeterRRVogue Member Since: 22 Jan 2022 Location: Brackley Posts: 72 |
Hello everyone, I'm new to this forum as I recently purchased my first RangeRover Vogue 2011 4.4 TDV8 from an Carpart auction. I took a bit of a gamble on it as it only looked like a faulty starter. However when the car was delivered to me last week, I quickly realised that the extent of damage is much worse. Upon opening the oil cap, I was horrified to find a massive build up of oil sludge which tells me that either the engine wasn't serviced for a very long time and/or it had a coolant leak which caused the sludge build up. Either way, I tried hand cranking the engine through the pulley but I couldn't move it which makes me believe that it's seized. The car has done 135k miles. This means that now I have couple of options, 1) try selling for spares 2) replace the engine.
22nd Jan 2022 2:05pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1215 |
If you only paid 5K for it I'd have an exchange engine fitted. Have you had a quote for an engine plus fitting? |
22nd Jan 2022 4:33pm |
That's what I am currently thinking too. However looking around, the second hand used engines seem to sell for around £7k + fitting; if I go down the route of a reconditioned engine (engine only so no turbos, etc) they seem to be around £5k incl. fitting (on exchange basis). With the reconditioned turbos and all, it might be close to £7k if not more. These are just prices I've found on eBay so ballpark really, as I haven't ready called anyone yet. |
22nd Jan 2022 4:57pm |
Thanks for flagging 'Zebedee'! It appears that someone has already moved my post to the L322 section (Thank you whoever it was!) |
22nd Jan 2022 4:59pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3235 |
Defo get an exchange engine / engine repair if you only paid £5k. 2012 TDV8 Vogue (L322) |
22nd Jan 2022 5:01pm |
LiftedDisco Member Since: 13 Nov 2019 Location: Towcester Posts: 31 |
Speak to Mick Loughran at Loughran’s of Towcester (opposite Tesco).
22nd Jan 2022 5:32pm |
Thanks for the tip "LiftedDisco". Never been to Loughran's as I'm fairly new to the area, but will pop in on Monday to speak to Mick. Do you know whether they would be able to do the engine swap as they seem to be a tyre shop.. |
22nd Jan 2022 5:37pm |
The tyre shop bit is closest to the A5 - the bays at the far end (ie nearest to where you drive into their yard) is just LR stuff and they are stupidly busy.
23rd Jan 2022 9:11am |
Thanks! I’ll pop in tomorrow, but more I’m thinking about it (mostly from the financial perspective) I might be better off just getting another one and sell this one for spares.. it just doesn’t look like I can do an engine rebuild for less than £8k. Even used engines that I can find are selling for £7k + labour.. |
23rd Jan 2022 10:23am |
May be worth more as a working car in today's used car market. 2012 TDV8 Vogue (L322) |
23rd Jan 2022 11:46am |
Thanks 'JayGee'. Looking at prices of 2011 used Vogues on ebay/Autotrader, I don't think that's the case. If i spend north of £7-8k on the engine that brings the cost of this car to 12-13k before sorting out a few little bits and pieces that might inevitable crop up once the car actually drives. And i doubt the car will be worth more than £13-14k if I try to sell private. |
23rd Jan 2022 2:07pm |
Fair point as long as you can sell the parts for the same as you paid for it. 2012 TDV8 Vogue (L322) |
23rd Jan 2022 5:01pm |
