![]() | Home > General (L405) > How Do You Guys Lock Your FF's? In Light Of Recent Thefts? |
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1041 ![]() ![]() ![]() |
Also use the keyless. Keep the keys well away from the front door though, in a foil lined box. Mrs S thinks I’m being obsessive…. |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3760 ![]() ![]() |
I use the Keyless entry but double lock every time 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
Keyless double lock, keys are kept in faraday bags.
aja500 Member Since: 15 Oct 2017 Location: South East Posts: 826 ![]() ![]() ![]() |
I only learned how to turn the keyless entry off last week from this video below, at which point I turned it off.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35494 ![]() ![]() |
I've switched off keyless and programmed one press superlock (with chirp) using the iidtool...when the mirrors fold and the chirp sounds then i kmow its locked proper.. ... - .- -.
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2665 ![]() ![]() |
Double lock and use a police approved faraday pouch . |
Martin2 Member Since: 15 Jun 2020 Location: Northamptonshire Posts: 784 ![]() ![]() |
Keyless, double lock and keys in a faraday bag.
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 ![]() ![]() ![]() |
What’s the difference between the one and two press locks? And where do I get a police approved faraday bag? What do I put here then? |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1268 ![]() ![]() |
I double lock, keyless disabled and visual steering wheel lock https://www.ownerinfo.landrover.com/docume...c/G1803943 2018 SE SDV8 4.4 Byron Blue |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
Press the lock button once and the doors will lock only, press lock the second time and this will deadlock the car and switch on the alarm and the interior protection sensors… I’m guessing most that get stolen only have the lock button pressed once????? |
luxmoggy Member Since: 19 Jun 2020 Location: Trier Posts: 471 ![]() ![]() ![]() |
After reading this I will make sure I am double pressing the lock. SDV8 AB MY 2020
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2593 ![]() ![]() |
Double lock and key with the others in a Faraday box (even though they’re UWB). |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 462 ![]() ![]() ![]() |
Always double lock and keep the keys in a tin. As extra precaution I use a steering wheel lock, have fitted a dummy OBD plug, and have a ram post on the drive. (Not that I’m paranoid) |
i reckon you're right Craig.... ... - .- -. Y. O. L. O. . |
