![]() | Home > Technical (L322) > 4.4 TDV8 Vibration/Rumble - RPM related |
hotpotatojr Member Since: 05 Oct 2021 Location: Blackpool Posts: 71 ![]() ![]() ![]() |
Hi,
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
just read you other post UJ is also a likely culprit 2012 Vogue 4.4 TDV8 - Current
Hi,
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 982 ![]() ![]() |
Measure & record engine speed, turbine speed, output speed and the EDS 2 solenoid current vs time using IIDTool or similar and analysis of the results will tell you whether it’s the TC LUC causing the vibration. Never seen results from an 8-speed before, so would be interesting |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 814 ![]() ![]() |
HP jr
JNC Member Since: 23 Feb 2020 Location: UK Posts: 293 ![]() ![]() ![]() |
I’ve experienced similar too.
If I were to describe it,
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2562 ![]() ![]() ![]() |
There are lots of heat shields that will resonate if touching something. |
Is it possible....
@RRPhil - thanks. Not invested in IIDTool yet (only had the car since October) - top of my list so will follow advice and report back!
jackie-o Member Since: 15 Jun 2018 Location: Sweden Posts: 226 ![]() ![]() |
Did you check heat shields?
Yep heatshields checked - I couldn't see any issue. I had all the mid ones off when I changed the centre prop bearing.
Checked my shields too. No obvious problem.
Some more insight into symptoms...
