2010 TDV8 4.4 Fuel guage playing up. | |
Ok, thought it best to show queary as a timeline showing issues ‘ actions…
14 Oct 21 Find fuel guage needle at 1/4 having just filled 80L 1 day ago doing approx 10m
19 Oct Booked in local LR indie garage to have sender unit in tank under back seal cable connectors repaired (LR service/fault) £200 (garage tell me was very difficult to sort as a part of sender unit broke while trying to reinstall it and the had to locally manufacture something to get it back in place - quite common apparently)
Dec 21 Noticed after 1st fill up since repair, distance to empty not synced with guage needle reading as I remember from pre fault?
Jan 19 22 Filled up for only 2nd time since repair to find distance to empty reading down about 60 mile as normal reading - then after driving for about a further 40/50 mile, gauge needle still at full position and distance empty down about 40/50m level, which is in sync with my actual number of miles driven.
So question is.. what’s going on with the guage reading as it’s still calculating distance to empty readings - albeit lower than before.
Jan 20 Rang garage who said all they done was take sender unit out, snip off the cable connectors and crimp cables (As per LR advisory) and put it back - albeit a bit broken, and quote me £450 + vat for a new LR one.. - plus fitting.
My thoughts are:-
Are there any other cheaper equivalent ones - Advanced Factors etc
Am I being mugged off?
What’s the groups thoughts???
Thanks in advance.
