![]() | Home > Technical (L322) > Air suspension schematic 2012 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35485 ![]() ![]() |
have you looked in the WM Steve? ... - .- -.
SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 258 ![]() ![]() ![]() |
Hi Stan
Picked the car up from the garage tonight, they had a good look at it today, apparently passenger side airbag has a small split in it. Now looking at about €1200 to replace both front units.
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2562 ![]() ![]() ![]() |
The vehicle will slowly level downwards but a leaking 1 side will put more weight on the other side making it lower anyway. |
After shut down it periodically wakes up to level itself so yes if one corner is down it will balance out across that axle. No need to do both sides and also no need to replace the whole strut as the airbag on it's own can be replaced. 2012 TDV8 Vogue (L322) |
