![]() | Home > Maintenance & Mods (L322) > Rust repairs. Any recommendations or precautionary advice? |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
It very much depends on what's presented, sir... Sometimes it's easier to cut out and replace using a formed panel other times not... Just depends on how your car presents! Impossible to advise any further without seeing the car I'm afraid... |
Charmer Member Since: 28 Aug 2012 Location: Alton Posts: 156 ![]() ![]() ![]() |
Thanks, I will take some photos and post them tomorrow. |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 475 ![]() ![]() ![]() |
Also be careful the inner arches have not corroded and spreads around the jacking points, quite common on these unfortunately and can result in an MOT failure once the corrosion has gone through the inner panel’s, also quite expensive to repair. |
Jacking points are still good at the moment. I removed the plastic sill cover to check. The sills are being repaired as well and this work is included in the estimates I have received. |
Snowy90 L322 Member Since: 24 Aug 2015 Location: Surrey Posts: 226 ![]() ![]() ![]() |
On the face of it it doesn't look too bad, as with all these cars a lot lurks beneath all the plastic, so they will have no idea what they need to replace until they get it stripped and all to see.
