Home > Maintenance & Mods (L405) > Replacement deployable steps motors
Discodazzla28
United Kingdom 2013 Range Rover Autobiography 4.4 V8 Orkney Grey
Hi
Can anyone help me with where to buy replacement deployable side step motors?
Thanks
Post #620222 16th Jan 2022 6:55pm
cass
Take a big dose of tranquillisers, sit down then try Maltings off road. £350 each I think
Post #620257 16th Jan 2022 11:49pm
Which side do you need sir?
Post #620258 17th Jan 2022 12:03am
essex boy
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
I am also in need drivers side if anyone can help sorry I have L322 07SC
Thanks Martin
Post #620330 17th Jan 2022 7:33pm
CMJ
2015 Range Rover Autobiography TDV6 Santorini Black
I think one from Land Rover recently cost me approx 600. Apparently they once were available without the bracket but this is now attached ? Or something similar. Cost me about another 250 for fitting. I checked at the time and seemed to be inline with the going rate. 2013 L405 AB 4.4SDV8 Luxor/Ivory, 2007 Vogue TDV8 Epson Green/Sand, 2008 Vogue TDV8 Buckingham Blue/Sand, 2003 Vogue 4.4 LPG Epsom Green/Sage, 1998 Vogue SE 4.6 LPG Epsom Green/Cream
Post #620354 17th Jan 2022 11:34pm
Fitting the motor to a new bracket is an absolute mare! Well, it’s more the getting off the old bracket that’s the worst! Got - 2017 SDV8 Autobiography in Loire Blue
Post #620358 17th Jan 2022 11:52pm
Discodazzla28
Very Happy
Hi Craig, I need the left side (passenger) are you able to assist ??
As always appreciated the replies Very Happy
Post #620670 20th Jan 2022 11:41am
Yes sir, I have a set of used so can supply either?
Post #620674 20th Jan 2022 12:25pm
in addition to Craigs offer, these can be bought from here,
https://www.qepmtn.shop/index.php?main_pag..._id=265677 [right hand only ???] ... - .- -.
Post #620677 20th Jan 2022 12:47pm
Discodazzla28
Hi Craig
Is it just the motors you have available or are they with the brackets as well? I assume both are in working order? How much for the left side only?
Thanks
Post #620681 20th Jan 2022 1:17pm
Discodazzla28
Thanks Stan
Had a look but they only seem to have the right side and I need the left Sad
Post #620682 20th Jan 2022 1:18pm
