![]() | Home > Maintenance & Mods (L405) > Rear shock replacement advice required |
johnb8538 Member Since: 15 Sep 2016 Location: Glasshoughton Posts: 71 ![]() ![]() ![]() |
Funny how when you notice a little niggle it becomes your obsession haha.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7909 ![]() ![]() ![]() |
The air bags are the springs, not the shockers.
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2685 ![]() ![]() ![]() |
If a warranty helps you sleep at night, go for it. I've only had one once which i've just cancelled after 3 years on my 405. Assumed incorrectly that things were covered that clearly weren't. Be aware that any item shown as advisory will not be covered, that's what I was later informed anyway. Age old adage, save the money , this should give you more than enough to cover unexpected jobs, wish I had tbh.
I think you've summed that up spot on so no criticism here thank you. The height between tyre and bodyshell didn't drop on any corner overnight which i would have assumed would be an airbag leak on the offending corner but when you get out of the car and the ride height has settled that back right corner is the lowest which made me think in "old terms" the shock absorber is failing. Ill certainly let you know what the diagnostic says. |
Agreed, Ive only ever had one paid for warranty years ago and they never paid out anything on it, always said wear and tear etc.. The free RAC one I had recently to be fair they've paid out nearly two grand on five items before it expired. There was a reduction due to age and mileage on every item claimed so yes its not the safety net you hope it would be. Thank you for the tip on the AA! |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
if there are no leaks in airbag then a re set on ride Hight is required and possible a new ride height sensor. Shocks do not determine the ride Hight the sensors do by adjusting the air bags.
