Home > Technical (L322) > TD6 blowing fuse 39 |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3978 |
Fuse 39 protects the steering lock ecu.Why it should blow in the manner you describe l have no idea but it’s a start. |
15th Jan 2022 8:28pm |
If you click on Wiki at the top right of the page and go down to INFO you will see electrical circuit diagrams.
15th Jan 2022 8:49pm |
John22000 Member Since: 25 Apr 2019 Location: Manchester Posts: 6 |
If I’ve been reading the circuit diagrams and the system description and operation manuals correctly fuse 39 seems to cover the auxiliary feed to both the steering lock and immobiliser ecu’s.
15th Jan 2022 10:38pm |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
A high resistance would reduce the current as you say, it does sound to be a really odd issue. BMW i3 Electric Car
16th Jan 2022 4:17am |
The only thing the second position on the switch operates is the starter circuit. Given that everything is ok until you go to the the second position it does suggest that the earth fault is associated with the starter circuit. This is more so as when you start the car without the fuse and then put the fuse back in everything is ok ie the starter circuit is out of circuit.
16th Jan 2022 9:07am |
Made progress but I honestly don't thing it the end of the saga..
16th Jan 2022 6:39pm |
