![]() | Home > Maintenance & Mods (L322) > Coolant flushed, 7 litres went in… what about the rest??? |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
So as posted elsewhere on this very forum, I’ve successfully replaced my pulleys, alternator, water pump and ac compressor.
I bought the Halfords coolant tester and checked my coolant mix.
Cheers @bean
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
I haven't done an L322 Super Charged yet. But my gosh that little BMW E30 1.8 four cylinder of my daughter had a few surprises for me as well. I was confident it was all empty, therefore I was also confident that despite the car holding temperature and heat coming through at the half way point it couldn't be right. It took me nearly four hours to get the air out, using the old fashioned way of leaving the pressure release valve off let it bubble a little bit and try and be quick to shut it off, and keep massaging the hoses. Fours hours later I had all fluids in, but at least I knew everything was in. And the car has been running so stable and sweet that I think the previous owners gave up too soon.
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 ![]() ![]() ![]() |
Tbh mate I don't see any reason why not it shouldn't work on any car. I'd get it if the expansion bottle was in the boot but that's never been the case unless you own a beetle or a squashed beetle (porsche). Give it a try mate and see where it leads you too. I remember seeing a while ago from a completely drained engine it takes 10litres too fill it up properly but that's including loosing all the coolant in the impossible places like in the valley pan on a 4.4 m62.
