Fuel tank removal allowing for other jobs, easily. | |
So guys,
If you take a look at the attached photo you will see the rust that will need repairing some time and that will involve welding and grinding. You can also see the fuel filler and tank cover are right up there in the way... and the petrol fuel tank isn't far off either.
So with that in mind, I will absolutely be removing the fuel tank and filler neck. While i've reviewed the workshop manual, I can see what is involved - even removing the centre console to remove the handbrake cable (!!).
A couple of things:
* How long should I reasonably expect for the tank removal to take? As a newbie to L322.
* Manual doesn't specify anything about exhaust, but I can't see how I can remove tank without that. Any comment?
* I wonder is there anything else that I could do while the tank and a few other bits are off? I am thinking that I might try and do a bit of a rust clean/treatment of some kind as the underside has plenty of scaling of surface rust. Heck, maybe I just drop the rear subframe and tidy it all up.
(07) 2007 3.6 TDV8 L322 - 135k miles.
(05) 2006 MY Supercharged L322 - Zambezi Silver on Jet Black - 162k miles.
** Smiles per gallon - never forget **
