Home > Technical (L322) > FBH (again)
Goldstar
2011 Range Rover Autobiography TDV8 Stornoway Grey
FBH (again)
Morning all. Bit chilly here in the Chilterns over the last few days. I’ve been trying to use the FBH. Remote is paired and blinks green slowly when operating. The blowers come on and the ac orange light flashes at about 1hz for 20secs then at about 2/3 hz. But not obvious signs of heating. No smoke/fumes from under the car and no obvious heat after 15-20 mins. Am I being impatient or is there another issue? I’ve run Gap and it passes the tests ok. Stumped. Any help welcome thank you.
Is it YouTube for videos on this platform by the way? Thanks
Post #619783 13th Jan 2022 9:26am
Dolphinboy
Just piggy backing on this most recent FBH post, this my e of some use to people (altho not the OP sadly?|0
https://www.webasto.com/fileadmin/webasto_...rt-t91.pdf
Post #619792 13th Jan 2022 10:15am
Nylands
United Kingdom 2012 Range Rover Westminster TDV8 Zambezi Silver
FBH issue
Hi there
I tried mine out yesterday which ran for 30minutes before it switched off. There are the following conditions required which I found on here :
a) It must be at least 5oC or under
b) 1/4 tank of fuel
c) Doors locked
d) battery holding sufficient charge
Must say pleased with the result as windows / mirrors clear and the cab while not warm, the chill had gone!
Dave
Post #619800 13th Jan 2022 11:21am
