![]() | Home > In Car Electronics (L322) > 2012 L322 ICE having a hissy fit |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4323 ![]() ![]() ![]() |
Might be worth trying a hard reset via battery disconnect. There is a process which I can't remember right this second but it's something like remove both terminals off battery once it's gone to sleep. An expert will be along soon |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35487 ![]() ![]() |
a battery reset [in WM] would be my first suggestion as well..then check the battery itself and lastly bypass the BT unit, details are in the wiki.. .. ... - .- -.
OveredRanger Member Since: 10 Nov 2021 Location: Northampton Posts: 7 ![]() ![]() ![]() |
That's great, thank you. I've already tried the bluetooth bypass without success, both the DIY method in the wiki and using the bypass gadget also from a link in the wiki.
Matt Buckland Member Since: 27 Nov 2018 Location: Derbyshire Posts: 65 ![]() ![]() ![]() |
Disconnect both leads from the battery and short them together for a few mins, to drain any lingering power in the countless ECUs, etc. Be careful what you’re doing with the removed +ve lead (I.e keep away from shorting against body or engine components). 👍🏻 L460 460e PHEV AB. Belgravia green.
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2566 ![]() ![]() ![]() |
The phone pair message and empty radio frequencies are only indications that the system has reset.
I've spent this morning doing all of these. I've done the battery reset as Stan suggested but it hasn't made any difference at all unfortunately. ![]() I then managed to locate the surround camera module and disconnected the camera feeds, and even the module itself, but still no change. I noticed a couple of other things while playing with the system though: 1) The information displayed on the 4x4 information screen is completely wrong. It comes up as standard height, high ratio, gearbox in Park, steering pointing straight ahead, but if you do anything, it doesn't change or update. The reason I hadn't noticed before was when I checked it, those were correct, and if you raise the height, or go into special programs etc, the dashboard display shows the correct settings, steering angle etc. but, as it turns out, not the ICE screen. 2) Although my phone said it had connected to the Bluetooth, I wondered what would happen if I tried pairing it again so I deleted the LR Bluetooth connection from my phone. Now, when I try to pair it, it can't find it. However, I still have my old phone which is still paired with it. When I turn that on, that one says it's connected pretty much straight away. Is there a final common system receiver/unit/CPU/ECU that could interfere with/be unable to process data from all of these systems? |
the 'navigation system' pdf in the WM has loads of info...might be relevant to you problem.. ... - .- -.
Right, having spent a bit of time reading that, am I correct in thinking that the touch screen display unit acts as the central computer for the whole system and isn't simply a display screen, and that in all likelihood, the one in mine isn't quite dead, but has severe Alzheimer's so I need a new one? |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 775 ![]() ![]() ![]() |
Before you rush off to buy a new screen, I had very similar symptoms with my old 58-plate TDV8. I guessed, like you, that the screen was at fault. I bought a new one and spent many hours pulling the car apart to replace it. Once it was all back together, I discovered that all the symptoms persisted. There was nothing wrong with my old screen which is now sitting in 'stock' with lots of other bits and pieces.
Apologies for taking a long time to get back but things have been a little busy.
Frans@Yamorna Member Since: 15 Apr 2017 Location: Tzaneen Posts: 147 ![]() ![]() ![]() |
I have exactly the same problem!!Have you found the source of water getting into the boot?Can one just replace the amp or must the amp be paired with the unit?I want to get a used amp but not sure it will work without pairing?How easy/difficult to remove the amp? Thanks. 2012 TDV8 Vogue SE 4.4 |
I hate being right all the time...... ![]() Actually, I do hate it on this occasion because this means that my 2012 could go the same way as my previous Vogue. Happy to have been of service! ![]() ![]() |
Providing it's like for like (Firmware version etc must match) then it's plug and play. The older I get, the more I realise that people confuse wrinkles for wisdom ![]() |
Ever found where water entered? 2012 TDV8 Vogue SE 4.4 |
