![]() | Home > Technical (L322) > Charging Voltage Low? |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6766 ![]() ![]() ![]() |
Seems a wee bit low David. When i first start mine, it sits around 12.x volts, then goes to 14.x volts after a few minutes.
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3197 ![]() ![]() ![]() |
That’s what is kinda confusing me to be honest…
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
Double check all earth connection between engine / body / battery, any poor connection here will drop a few volts giving the symptoms you have. If you have a multimeter, measure voltage between engine and battery negative with loads on and engine running, it should be 0v, you may find a small voltage indicating poor earth connections. BMW i3 Electric Car
Thanks |
lambo911 Member Since: 13 Jan 2022 Location: St Albans Posts: 92 ![]() ![]() ![]() |
I would think it is an earth too. But check the resistance in any cables as the wiring can go bad |
Thanks guys. I agree with it likely to be an earth fault. I guess it's at an age where things break internally now.
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2279 ![]() ![]() ![]() |
I had similar on mine and changed the loom from the battery to starter to Alt and cleaned all the earths been fine ever since (about 80k miles ago )if it helps
Did a bit of digging on this earlier and am not seeing an earth fault when checking with the meter or when running a cable from the engine to the battery.
CongoBoy Member Since: 11 Sep 2020 Location: Wiltshire Posts: 126 ![]() ![]() ![]() |
Hi David,
That’s a good point.
