![]() | Home > Technical (L405) > Old chestnut DPF |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1261 ![]() ![]() |
As a matter of interest, What engine do you have and year?
spaceman1000 Member Since: 10 Aug 2021 Location: Oxford Posts: 15 ![]() ![]() ![]() |
Hi Kot
Landphil Member Since: 03 Oct 2016 Location: U.K. Posts: 119 ![]() ![]() |
I’m tempting providence here but what the heck.
Yes how could I resist
Oil dilution occurs every completed Active Regeneration, which will take place between every 100 odd miles to 250 odd miles etc its not just when a forced Regeneration is done. Like you, I have never seen an Amber which proves your DPF system is working and your journey styles suit your car, as you are not unknowingly ending your Active Regenerations prematurely. However if your journey style is such, that you sometimes never complete an Active Regeneration, the system will try when conditions are met, to do another Active Regeneration and so on etc that's when it can mount up and will eventually create an Amber alarm. 2018 SE SDV8 4.4 Byron Blue |
My car is an April 2015 manufacture and you are obviously right about the regens. My point is that while regular short trips don’t suit DPF equipped cars, and the LR architecture seems more problematic than most, the system seems for the most part able to cope. On a Forum like this you will always see more problems than in the wider world, as this is where people come for help, and solace.
Gents you are all correct methinks.
