Home > Technical (L322) > Battery: How low to get faults displayed?
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
For a while I have been getting on and off some faults showing up for about 5 seconds after start, then going away. Usually its "Transmission fault reduced traction" and "HDC off" etc. Drives fine. Today had "suspension fault-max speed 30" followed by lowering to bump stops. Turned off, restarted and been fine for the rest of the 80 mile journey.
Before leaving, battery read 11.9v, when running 14.7 and when I got back with engine off 12.4-12.3.
Volts drop to 11.6 when cranking.
Is that the likely cause of faults flashing up?
New battery time (it is from August 2017).
Thanks
Post #619589 11th Jan 2022 3:56pm
dhallworth
I've had 2 SC's now and both have manifested low batteries with the "Transmission Fault Reduced Traction" error message.
I've charged both of them and it went away but came back a while later. Swapping the batteries cured both.
11.9v when sitting switched off is low, it should be over 12.
Interesting you're seeing 14.7 with it running, my IID tool reports my car sitting at 13.2v constantly so am wondering if my alternator is knackered.
2007 Range Rover Supercharged in Java Black with Ivory Leather
Post #619599 11th Jan 2022 4:44pm
vs322
Greece 2004 Range Rover HSE 4.4 V8 Java Black
HDC inactive / HDC OFF and the like, mean "LOW BATTERY" in the L322 dialect Thumbs Up
Post #619617 11th Jan 2022 7:26pm
