Home > Maintenance & Mods (L322) > Change my air filter ... yes just the one
Chrali
Hi Guys
The last 3 services were so called oil services, so I had no idea when the air filters were changed. Order some Hengst filters but I couldn't undo all of the air filter box screws; as 1 was badly corroded, so now I really wondered how old the filters were. I orders 12 new air box screws; which all came individually packaged (over kill) and set to it.
Happily the passenger side filter was new. On the drivers side I had to used a small hacksaw to cut a slot in it corroded airbox screw and used a large flat screwdriver, then pliers to twist it until it was out. Lo and behold the air cleaner in that side was filthy Shocked I don't know decided they could only be bothered to change one, but doesn't say much for the garage involved.
I replaced the filter with a nice new one and changed all 12 air box screws with new ones and added a dab of grease to the screw heads to prevent future corrosion.
 Encourage alternative fuels, use all the petrol!
2012 Range Rover Vogue 4.4 TDV8
2006 Mercedes GL420 CDI
2006 Porsche Cayenne Turbo S
2006 Jeep Commander 3.0 CDI with GDE HOT Tune
1997 Nissan Patrol 4.2 GRSE
1995 Vauxhall Monterey Diamond 3.2 v6
1994 Range Rover 4.2 LSE Beluga Black, Softdash, Brooklands Body Kit - Loved it!
1993 Range Rover 4.2 LSE ended up converted to 300tdi
Post #619367 9th Jan 2022 7:16pm
GraemeS
My left filter is always clean because the secondary turbo is only occasionally used.
Post #619369 9th Jan 2022 7:30pm
Ffrr-lover
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
I had the same issue with me air intake boxes… screw rusted to the point of disintegration.
I was lucky enough to find the right screwdriver heads and body weight to get them moving so I could undo them.
I’ll be ordering some soon too…
Luckily my filter was a normal colour, unlike yours! Shocked Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #619378 9th Jan 2022 8:42pm
Chrali
Yeah I had to press down on some of them and use weight too, on that one and some of the others. Why couldn't LR just use clips on the airbox like everyone else Shocked
Cost about £14 inc P&P to get the 12 screws from a Jaguar site.
Perhaps the other filter is new, perhaps not, at least its clean Very Happy, but I'd have thought they both would be just as dirty. I'd wouldn't have expected 1 air intake per turbo Confused Encourage alternative fuels, use all the petrol!
Post #619402 9th Jan 2022 11:19pm
Yes only the OS filter gets used 95% of the time... Thumbs Up
Post #619405 10th Jan 2022 12:28am
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Confused
Or heaven forbid, Stainless steel screws, I changed mine to stainless, cost less than £2 from eBay, problem solved. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #619412 10th Jan 2022 5:25am
gettingold
Excellent persistence Thumbs Up , and find a different garage now. visiting from www.rrsport.co.uk
Post #619421 10th Jan 2022 8:36am
AJGalaxy2012 wrote:
Confused
Could you post a link for those that wish to follow your lead sir? 👍
Post #619422 10th Jan 2022 8:42am
AJGalaxy2012
I'll try and find it, my 322 is now long gone so I dont have anything to cross reference against. I replaced all of the fastenings around the bumper, wheel arch liners and the slam panel at the same time, it looked so much better. Easy enough to find on eBay. BMW i3 Electric Car
Post #619445 10th Jan 2022 11:08am
Post #619446 10th Jan 2022 11:30am
