Home > Technical (L322) > replacing heater motor on a 2012 help needed please
Furnitureman
United Kingdom 2012 Range Rover Westminster 4.4 V8 Cairns Blue
S0 ive ordered the new heater motor and had a good search on here for help but almost all info is on the earlier cars, if anyone has links to videos or just info on how to remove the end caps, vent caps, top dash with the two vents and any other info before i start ripping the bits out i would be most grateful, im hoping to not have to strip everything out but go through the top so any info from people who have done this would be great, i indent to do a full writ up for others with later cars.
Thanks in advance
Craig 2012 Range Rover Westminster 4.4 TDV8
2006 Discovery 3 HSE 260k miles and still going strong with a new owner
Post #619313 9th Jan 2022 2:58pm
=dj=
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Orkney Grey
I think I'm staring down the barrel of this with my 2012 as well, having had the FSR replaced on Dec 23rd and the fans have stopped working again today, ugh.
So I've been spending a little while researching this today as well - as you say, there's a bunch of differences from the earlier models. Here's what I have so far...
1. Firstly, on a 2010-2012 L322 the fuse for the front heater fan is in the rear fuse box (behind the right hand panel in the load area), marked with a fan icon, F21, 40amp. When my FSR died the front fan ran 24/7 so I had to pull this fuse.
("dexion7" shows an image of the fuse location here:
https://www.fullfatrr.com/forum/post577631.html#577631)
2. "Arbuckle" meantions replacing the FSR but then had to disconnect the battery for 10 mins before the fan would run again (perhaps this cleared an HVAC fault?)
https://www.fullfatrr.com/forum/post498825.html#498825
3. Partial access to the fan can be made from the engine side by removing the cabin filter / pollen box housing, allowing you to test how tight the fan has become. A squirt of lubricating oil on the spindle might loosen it up and help delay full replacement. (Garnerj with a 2011 confirmed access via box removal)
(See "Joe90" post https://www.fullfatrr.com/forum/post552166.html#552166)
UPDATE: Although "SveinHa" suggests in another post that might not be a great idea...? https://www.fullfatrr.com/forum/post407877.html#407877
4. Partial access might be possible from under the dashboard too, see "t5pete"'s photo here https://www.fullfatrr.com/forum/post616241.html#616241
5. "L19 MUD" documented the fan replacement on their 2012 ... and, just, wow. The full monty strip down.
https://www.fullfatrr.com/forum/topic58107.html
6. "SveinHa" did a couple of posts showing the difference between how a stuck heater fan spins verses a new one, and then the "shortcut" mod to the full strip down he did on his late 2009.
https://www.fullfatrr.com/forum/post395050.html#395050
Last year I fitted the Naviplus unit (see the general thread on this here: https://www.fullfatrr.com/forum/topic56194.html) and the instructions for that guided me through stripping down the dash - I can find them and PM them to you if they'd help?
Post #619381 9th Jan 2022 8:59pm
Furnitureman
WOW that’s great thanks for the info, I’ve got a gap iid and there are no fault codes for the hvac but I may disconnect the battery just to rule that out 2012 Range Rover Westminster 4.4 TDV8
Post #619382 9th Jan 2022 9:04pm
Peter B
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Santorini Black
Hi Furnitureman, my fan has just failed suddenly! How did you get on with yours?
Post #646717 28th Oct 2022 3:25pm
