Home > Technical (L322) > The dreaded adaptive dynamics fault |
BINDERMINDER Member Since: 01 Jan 2022 Location: Ofallon Missouri Posts: 6 |
Sorry, This is in reference to my 2011 RR L322 with 5.0 SC |
6th Jan 2022 7:13pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4307 |
In the workshop manual there's a file called diagnostic codes to look up codes. Download from Wiki (scroll to bottom of the page) Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
6th Jan 2022 7:25pm |
Thanks Dr. Rob! It appears to be a code for power supply for the lower accelerometer or transducer. Wonderful... Now can anyone with more knowledge than I tell me where to go from here? |
6th Jan 2022 7:42pm |
Good but can't help you anymore as knowledge is zero on that topic Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
6th Jan 2022 8:33pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3257 |
The system uses 3 accelerometers. The easy one to access is on the right rear side of the spare wheel well and is also the easiest to damage so start there. I think the others are hidden behind body panels. 2012 TDV8 Vogue (L322) |
6th Jan 2022 9:09pm |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
Binder
6th Jan 2022 9:51pm |
klj Member Since: 24 Aug 2019 Location: Frozen North Posts: 66 |
Hi. I fitted two new solenoids and soldered the wires. No problem since. They're cheap Ken ----------------
6th Jan 2022 10:40pm |
As I've just purchased this "big brother" to my '11 Jag XKR back in October, I haven't done anything but change the oil and the wipers. I've had some time today to read as much literature as possible on this issue (and many others) my fullfat folder is growing quite large and I will be using this new found knowledge for the CD player, the front cigar lighter receptacles and the rear entertainment quirks. From what I have found, C1B14-1c relates to Sensor supply 1
6th Jan 2022 11:36pm |
One other thing, the air will go out of the front shocks overnight. This was ocurring before the AD fault.
6th Jan 2022 11:40pm |
So.. my mistake! The definition 0f DTC c1b14-1c that I had read over earlier pertaining to the accelerometer was from a 2006 RRdocument. RJFF directed me to the google docs RRWM from 2014 and it says this DTC is for the height sensors. I won't ask why... but why??? Thanks for the insight. Anyone with knowledge of best methods for testing will be my next best friend! |
7th Jan 2022 5:07am |
Thanks for the link - that's a world of useful info! 2012 TDV8 Vogue (L322) |
7th Jan 2022 3:46pm |
