Home > Maintenance & Mods (L322) > 2010 4.4 TDV8 Cabin heat issue
BenRK
I've noticed recently that the dials on my heating system seem to have absolutely no fine control. On the lowest setting (turn all the way to the left, think it's 17 degrees) the air is cool as you would expect
However turn it up one notch and it is immediately red hot, you can then turn it all the way up to the highest setting and it's the same.
It's literally cold, or hot and I'm sure it didn't use to do this before. I'm getting no fault codes showing up and it's quite annoying not being able to get a comfortable temperature
Any ideas?
Thanks
Post #618999 6th Jan 2022 4:15pm
JayGee
Where is your hot/cold vent control set at (the red and blue horizontal wheel) 2012 TDV8 Vogue (L322)
Post #619002 6th Jan 2022 4:37pm
BenRK
Just sat in the middle
Post #619013 6th Jan 2022 5:53pm
JNC
United Kingdom 2011 Range Rover Vogue SE TDV8 Nara Bronze
I have this issue too. I haven't looked into in yet but it's hot unless on full cold.
The face vent dial works as expected.
Post #619162 8th Jan 2022 12:31am
