![]() | Home > In Car Electronics (L322) > GPS Tracker Sim Cards |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35511 ![]() ![]() |
have a look on amazon for a three data sim..normally around £35 for 24gb and 24 months .. ... - .- -.
RJPotts Member Since: 19 Aug 2021 Location: Durham Posts: 207 ![]() ![]() ![]() |
Thanks Stan.
pretty sure you activate in a phone and then transfer sim to the tracker...hopefully someone who has done this will confirm. ... - .- -.
Hi Stan
1p mobile??
That looks as though it could be just the job!
Why not buy a 1Gb 3 data sim from Amazon for £6.15 and try it. The sim lasts 30 days, if ok then buy a 2 year one. |
I might have done prior to calling at a Three store today. They confirmed that their data sims will not be suitable / have no text functionality. 2010 Range Rover Autobiography TDV8 Santorini Black
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1455 ![]() ![]() |
I used a GiffGaff sim in the previous tracker in my Westie. Mainly because it still uses a 2G connection as you don't need any data, just a text facility.
Barmybrummie Member Since: 03 Apr 2021 Location: Somewhere in the valleys Posts: 683 ![]() ![]() ![]() |
I don't know where you got your tracker from, but I bought mine from global trackers and comes with a sim card already installed. Only costs £4.95 a month. I've had mine 4 years, was installed on my Saab but now it's on the fatty. Can't fault the service and works perfect.
JNC Member Since: 23 Feb 2020 Location: UK Posts: 293 ![]() ![]() ![]() |
Just check if the tracker is 2g or 3g. You then need sim card to suit.
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 454 ![]() ![]() ![]() |
I've used GiffGaff SIM's on GSM gate openers and remote locations where I have fitted surveillance equipment with great success.
JNC, they do now have an app, I use it on my android. It's a bit of a faff to set it up but does work great. |
