![]() | Home > My Range Rover > 4.4tdv8 L322 boom or bust |
Davidmudley Member Since: 26 Dec 2021 Location: Surrey Posts: 80 ![]() ![]() |
Does anybody know what the boost (turbo) actuator is called in the workshop manual? I’ve been trying to find information on it but can’t for the life of me track it down, scrolling through or using the word search.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8716 ![]() ![]() ![]() |
Charge air valve or something like that. (No.4)
Replacement are available as pattern now for about £80 on eBay. They list as secondary turbo shut off valve. https://www.ebay.co.uk/itm/4-4-TDV8-SECOND...635-2958-0
OK so the bit that sticks is called the shut off valve vacuum actuator and connect to the shut off valve mechanism.. (no. 5) Basically rave tells you to take the whole valve body out from underneath. There doesn’t seem to be a specific set of procedures for replacing just the actuator, but as said they are available off Maltings etc for about 80. So it’s a whip the whole lot out job, change the actuator, put it back in. There is nothing that can't be fixed with a hammer😜😜 FFRR 4.4 SDV8 Autobiography Santorini Black. KIA E-Niro 4+ 2021 Discovery 5 D300 MHEV commercial |
That’s really helpful. Thanks Current: Range Rover L322 4.4tdv8, Porsche 911 (996) Carrera 2, BMW 535d Touring, Skoda Fabia, BMW S1000XR |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
I’ve removed mine as part of other work. It came out fairly easily and quickly.
So things have taken an interesting turn (and I suspect for the best). After winning the auction, and has had been said on some negative reviews of Reading no reserve auctions (Sterling Cars, Reading), I called a few times to arrange to view / collect the car. Each time I was told that I needed to speak to the manager as the FFRR was at the garage and they weren't sure why.
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 696 ![]() ![]() ![]() |
There’s nothing stopping you registering to view both BCA & Manheim auctions online.
