Home > Maintenance & Mods (L322) > Turbo issue |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7809 |
I’d check the rubber hoses on the donut under the engine cover for signs of splitting or if the plastic has cracked.
31st Dec 2021 5:03pm |
Sorry, FSR for blower is sort of at the back of the heater control panel. You can get to it by popping off the side panel and reaching in. Think there might be a guide in the Wiki….. top right….
31st Dec 2021 5:05pm |
Tswitch Member Since: 24 Jan 2020 Location: Derby Posts: 12 |
Thanks,
31st Dec 2021 5:23pm |
So checked maf sensor today, completely clogged. Cleaned and refitted
1st Jan 2022 4:16pm |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 688 |
As you know, the 4.4 tdv8 has sequential turbo's & the second turbo kicks in around 2400rpm.......just when you said you get RP message. I would check the second turbo actuator arm to make sure that's not stuck, this happened to mine, took the actuator off, cleaned her all up & she's fine.
2nd Jan 2022 8:44am |
Davidmudley Member Since: 26 Dec 2021 Location: Surrey Posts: 80 |
Out of interest Fox889 How did you remove the actuator? I understand The passenger-side one is incredibly difficult to access, any guidance you can provide would be very interesting. Thank you Current: Range Rover L322 4.4tdv8, Porsche 911 (996) Carrera 2, BMW 535d Touring, Skoda Fabia, BMW S1000XR |
2nd Jan 2022 9:12am |
Have to confess, the Indy did all this for me!
2nd Jan 2022 9:22am |
Thanks, makes sense. I’m going to do the actuator fix (poke and lube 😉), but also curious to know what the removal entails. Current: Range Rover L322 4.4tdv8, Porsche 911 (996) Carrera 2, BMW 535d Touring, Skoda Fabia, BMW S1000XR |
2nd Jan 2022 10:20am |
What’s the actuator thing that’s at the front near the bottom of the radiator? That’s the part Land Rover updated at some point. Someone did a post about it somewhere… can’t find it….
2nd Jan 2022 11:09am |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
I think that part is the charge air inlet valve. There was a mod to change the lnkage connector design.
2nd Jan 2022 11:17am |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8550 |
Look to see if you have the updated hoses on top inlet before you go and start taking them all off…..
2nd Jan 2022 11:44am |
Have the old ones on, will smoke test next week end, bought new hoses just in case.
2nd Jan 2022 9:05pm |
I’d fit the new hoses anyway, as you have bought them. Can’t do any harm and will sort any future issues in this area.
2nd Jan 2022 9:42pm |
So dived in and back left rubber hose split. All changed and okay now.
6th Mar 2022 12:10pm |
