![]() | Home > In Car Electronics (L322) > GPS antena sees 5 sats but have the red line through GPS |
RJPotts Member Since: 19 Aug 2021 Location: Durham Posts: 207 ![]() ![]() ![]() |
I believe somewhere in one of the secret menus you can see the values seen from each satellite? I'd start with that, maybe it's giving 5 false signals?
nemmi69 Member Since: 16 Jun 2015 Location: Peterborough Posts: 104 ![]() ![]() ![]() |
Its how i knew that i was seeing 5 satelites. PS code is 134679 What doesn't kill you is just bidding it's time. |
Do the values change if you move the car? 2010 Range Rover Autobiography TDV8 Santorini Black
yes they are changing. also tried changing theorintation of the car when i parked at differet places. What doesn't kill you is just bidding it's time. |
Probably worth getting a cheap gps aerial as the next step. 2010 Range Rover Autobiography TDV8 Santorini Black
Thinking of this
Just a thought, with the hidden code there is an option to update the software. Any ideas how they do it? What doesn't kill you is just bidding it's time. |
Tried a new antena still no change What doesn't kill you is just bidding it's time. |
