Home > Technical (L322) > M62 V8 4.4 help |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 584 |
So, came back from work, a 45km commute in various traffic conditions. Nothing happened. Left home again, to run some errands another 20 +20 km half of which in traffic and half on the motorway. Came home and opened the bonnet to find coolant spilled. It seems as if it was a single release event. But the cap kept weeping slowly and after a few minutes from shutdown a small quantity of coolant has been expelled on the reservoir mounting bracket...
29th Dec 2021 6:22pm |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 901 |
I can see why your having issues you are over filling and not bleeding correctly
29th Dec 2021 10:22pm |
Yes, I'm intentionally overfilling to see if bubbles would emerge from the small feeding hose opening. Please note that I haven't bled the system on the video. My intention was to detect bubbles from a possible hg failure.
29th Dec 2021 10:25pm |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 739 |
Hi, I have the same engine as yours
30th Dec 2021 1:50am |
Thank you so much.
30th Dec 2021 3:24am |
So, I checked the level and was at the bottom of the expansion tank, as expected. Upper hose was a tiny little bit sucked in. Topped up to "Cold" and started the motor. I was greeted by a steady stream of coolant through the return hole in the neck. Massaged top hose a bit a few times and each time the flow would be briefly interrupted then resume solid. Bled through the screw as well, although probably unnecessarily, and still no bubbles emerged.
30th Dec 2021 5:30am |
Still out shopping, picked new cap (not fitted yet) waiting on the thermostat...
30th Dec 2021 8:54am |
Okay, we might be on to something here, gentlemen.
30th Dec 2021 12:24pm |
Old cap off, new cap on. Barely any leftover pressure in the system after less than 4 hours of cooling down. No funny smell, either!
30th Dec 2021 1:59pm |
Wrapping this painful story up and fairly certain I'm not speaking too soon:
31st Dec 2021 12:55pm |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1345 |
Told ya
31st Dec 2021 1:42pm |
You were right all along
31st Dec 2021 1:45pm |
