Home > Maintenance & Mods (L405) > Deployable steps fitting issues help its driving me insane ! |
dennij Member Since: 23 Feb 2019 Location: Up North Posts: 450 |
Do they need to be activated via the CCF file? 2011 TDV8 Vogue SE |
31st Dec 2021 11:04am |
Discodazzla28 Member Since: 08 Jun 2021 Location: Wolverhampton Posts: 17 |
That’s sort of my question really? I’m not sure if they should just work or if I need to configure??? |
31st Dec 2021 11:20am |
Any ideas greatly appreciated |
1st Jan 2022 4:27pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
On a 13MY they are simple plug and play... How have you purchased the parts? |
1st Jan 2022 5:06pm |
OK, just reread your first post... Proposing you have been sold the correct module?
1st Jan 2022 5:09pm |
Thanks Craig
the car has been left to sleep locked and came back the next day and no joy. I haven’t done a hard reset yet. Haven’t actually disconnected the battery since I brought it. Assume I can just disconnect the one on the boot spare wheel well?
1st Jan 2022 5:17pm |
No, the 13MY doesn't have diagnostics for the steps or tow bar... Treat the system as a stand-alone system, sir...
1st Jan 2022 5:23pm |
I have had the fuse out and nothing different |
1st Jan 2022 5:25pm |
Explain to me what you have done/fitted and where about on the car sir... |
1st Jan 2022 5:27pm |
ok so I tried as follows:
1st Jan 2022 5:38pm |
Where was the plug in your vehicle? Where have you mounted the ECU? |
1st Jan 2022 5:46pm |
as you look in the boot the plug was the far right hand side, with a blank plate on it
1st Jan 2022 5:50pm |
Wire harness part ref - VPLWP0178
1st Jan 2022 5:58pm |
