Home > In Car Electronics (L322) > Ignition won’t turn off, help!
Deputy
United Kingdom 2008 Range Rover Vogue TDV8 Barolo Black
My key in dash 👍
Post #617725 27th Dec 2021 5:05pm
tb10
England 2005 Range Rover Vogue 4.4 V8 Tonga Green
Hmm ok, I don’t know about that ignition switch then but I’ve taken my older style lock apart previously as it jammed as you describe. Just check fuse 18 again. New fuse perhaps?
Post #617727 27th Dec 2021 5:18pm
Deputy
Is this a known issue?
http://www.fullfatrr.com/forum/topic53142.html
Post #617735 27th Dec 2021 6:00pm
What position is your gear shifter in? Can you hear the solenoid clicking when you press the brake pedal?
If the cable between the shifter and the ignition has a problem/seized then the key wont turn...
Post #617763 27th Dec 2021 11:27pm
Deputy
I can drive the car as normal so I can move the gear lever in any position you would normally. I just can’t turn the key anti-clockwise to switch off. It’s seized in position II, nothing else is wrong.
Post #617764 27th Dec 2021 11:36pm
Right... For the key to turn in the ignition, first the ignition needs to know the car is in Park...
So, if the cable has seized between the drive position of the shifter and the ignition barrel then it won't allow you to turn the ignition off (as the car will simply roll off down a hill if the P is not engaged)
Secondary, there is a switch/solenoid connected to the brake lights, this is why you need to depress the brake pedal to select gears from P...
Post #617772 28th Dec 2021 12:07am
Deputy
Is there a cable between the ignition barrel on the dashboard, just left of the steering wheel, and the gear shifter?
Post #617778 28th Dec 2021 12:42am
Deputy
I forgot to mention that the key barrel appears to be seized in position II BUT I can pull the key out of the ignition. I was able to drive around with the engine on and key out.
I drove home and with the key out of the ignition, and being unable to shut the engine off, I went in to fetch the second key to see if it would turn in the ignition, but it didn’t work either.
I had to pull some fuses and disconnect the battery in the end to shut off the car.
Post #617785 28th Dec 2021 9:47am
Worth a try spraying wd40 into the key barrel. I know people say you shouldn’t but I’ve always done it and never had any problems.
Post #617789 28th Dec 2021 10:53am
tb10
Certainly, on the early cars, there is a cable that activates when the gear selector is moved from Park.
https://tinyurl.com/3v6p6b2j
From looking at the microcat diagram, the switch 'appears' to be the same switch on the interior facelift models (March 2006 onwards?):
In the attached DropBox file, diagram 9 states "Release the gearshift interlock cable."
https://www.dropbox.com/s/ou8dfdfzoqiamh2/...8.pdf?dl=0
I had to take my ignition switch apart when I first had the car but, when out and on the bench (kitchen table!) the key will only fully turn to remove it if you simulate the gearshift interlock cable pressing onto the ignition switch ** this is important as you may think it is completely broken **
I also find that some of the diagrams in the workshop manual were perhaps written when the components were out of the car and not in situ so it may sound easy but, in reality, it may not be.
Hope this helps?
regards
John
Post #617790 28th Dec 2021 10:58am
Deputy
Hi John, thanks. This is very helpful.
Post #617792 28th Dec 2021 11:40am
Deputy
Think you’re correct since there does appear to be a cable between ignition and gear selector. Ignition probably doesn’t know when it’s in P but when it’s in D, how come I can pull the key out? That’s what I found confusing.
Is this be a replacement part or just a repair/ lubricant application to keep it from sticking?
Post #617802 28th Dec 2021 1:03pm
Deputy
Has anyone tried this fix?
Post #617972 29th Dec 2021 11:38pm
