Home > In Car Electronics (L322) > Ignition won’t turn off, help! |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3978 |
Disconnecting the battery -ve terminal should do it, it will disable the fuel solenoid and cut off fuel to the engine. |
27th Dec 2021 2:47pm |
Deputy Member Since: 23 Nov 2021 Location: Maidenhead Posts: 33 |
Didn’t work. Engine still running. |
27th Dec 2021 3:07pm |
Tried pulling fuse 18 to see if it resets ignition switch, no good. |
27th Dec 2021 3:17pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1228 |
Is it just idling or revving? |
27th Dec 2021 3:26pm |
Idling. |
27th Dec 2021 3:29pm |
Is there any smoke from the exhaust? Could be running on engine oil from a leaking turbo. |
27th Dec 2021 3:31pm |
You need to block the air inlets somehow to starve it of air. |
27th Dec 2021 3:35pm |
No. It’s the ignition barrel. The key won’t turn anti-clockwise to switch the ignition off. It’s stuck somehow. |
27th Dec 2021 3:38pm |
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 338 |
Fuse 25, 31 or 39 |
27th Dec 2021 3:45pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3240 |
or fuel pump relay in rear fuse box? Pulling fuse or relay won't be instant. Need to clear fuel in the lines and filter. John
27th Dec 2021 3:51pm |
Pulled 31 and that’s stopped the engine. Phew!!
27th Dec 2021 3:53pm |
Replaced the -ve battery terminal to try and start up.
27th Dec 2021 4:01pm |
Swap fuse 18 or check it’s clean. Mine had a similar issue and the fuse I used was not making a good contact. Glad fuse 31 worked |
27th Dec 2021 4:41pm |
Is yours a key in dash or key down by the handbrake? |
27th Dec 2021 4:46pm |
