![]() | Home > Maintenance & Mods (L322) > Diagnosing a bad torque converter? |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3263 ![]() ![]() ![]() |
Could be sticking caliper which is freeing off once rolling? John
lodelanelad Member Since: 14 Dec 2021 Location: London Posts: 59 ![]() ![]() ![]() |
That is a great idea - will check |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1002 ![]() ![]() |
Unlikely to be the torque converter lock-up clutch, I would have thought. It doesn’t engage until after the 2-3 upshift.
Thanks Phil - so torque converter judder would start at 24mph and go on for about 2.5 seconds as it engages? |
Basically, yes (at light throttle). Additionally, you can see from the graph that in 4th gear the LUC is operating in its ‘controlled slip’ mode where it continuously slips at around 3% to absorb torsional vibration. Again, this could be a possible source of vibration if the LUC friction plate was worn. Only in 5th & 6th gears is the LUC fully engaged.
