Home > Technical (L405) > Knocking noise from start at low speed in curves...
max2021
Germany 2016 Range Rover Autobiography SDV8 Baltic Blue
2016 RR L405/4.4 Diesel/ 100.000 km
Dear all,
when i start driving from zero km/h to about 25 km/h i have about 3 to 5 times a knocking sound coming in mostly cases from the back and, as far i can feel it, sometimes also from the front.
I can feel the vibration of this tock...tock tock...tock also. (not only hearing it)
The noise is only when i drive slightly left or right from the start.
The noise is basically not when i fully turn the steering wheel left or right.
The noise is not, when i start straight.
Seems like, that the noise is getting more intensiv after driving about 500 meters with gear reduction (off road modus)
The noise is not when driving faster than about 25 km/h in slightly curves.
Basically no difference if all oils are hot or cold.
All drive train oils are changed. Car has about 100.000 km long distance.
No offroad, no trailer.
Any ideas for this issue?
Thank you very much for your help!
Many greets!
Max
Post #617554 25th Dec 2021 11:12pm
pld118
Hi Max,
Hopefully this thread might be if interest
https://www.fullfatrr.com/forum/topic44796.html
Post #617567 26th Dec 2021 9:44am
