Home > Technical (L322) > Battery Drain Chasing
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
My alarm still keeps randomly going off and the other night it went off twice so I unlocked the car and left it unlocked.
I came down in the morning and the battery was dead flat, wouldn't start the car.
After charging up the battery to full I decided to embark upon a parasitic drain hunt to see if I could find out what is causing it.
I removed the earth clamp and put an ammeter in series and then left the car. According to the manual it should sleep after 33 mins even if not locked.
Luckily my multimeter has a datalogging function so this is the graph I managed to create from the data.
The vertical axis is amps with a unit scale of 0.2 The horizontal is time.
Interestingly within 4 minutes the car had dropped to 0.005A
I checked voltage drop across all fuses and not one of them gave me a reading to indicate a parasitic draw.
Stumped. Christian.
Current Cars
2011 Range Rover Vogue SE
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #617366 23rd Dec 2021 2:09pm
Caesium
More Data from the log
Measured over 3929 Seconds or 65 minutes at one measurement point per second once car had settled into sleep
Average draw when asleep 0.006A
Max peak draw when asleep 0.039A
Minimum draw when asleep 0.0A Christian.
Current Cars
2019 BMW X4
or
Post #617369 23rd Dec 2021 2:16pm
I would charge the battery fully, disconnect the battery -ve terminal, leave overnight and see what happens.
The battery drain data you have recorded seems reasonable to me, if not pretty good.
I suspect your battery itself may have a problem.
Post #617374 23rd Dec 2021 3:06pm
Caesium
The battery is 3 months old.
Duracell AGM. Christian.
Current Cars
2019 BMW X4
or
Post #617375 23rd Dec 2021 3:14pm
400-ascona
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Java Black
Try disconnecting the bonnet switch and bridging the terminals in the connector. I had this issue and got fed up with getting up in the night to sort it.
Charge the battery and then see what happens. Indicators should flash when you lock the car (even with the bonnet open once you've bypassed the switch).
Never had an issue with mine since I did this, and free to try to begin with. I will get around to replacing the switch one day! 05 L322 4.2SC
2016 Discovery 4 Graphite
Lotus Carlton
Ascona 400
Volvo V70R AWD manual
Suzuki 1200 Bandit
Velocette Venom
BMW R80/7
Daimler V8 250
Mini Cooper S Works 2006
Post #617376 23rd Dec 2021 3:18pm
Duracell AGM.
I would still charge and leave overnight Thumbs Up
Something is discharging it and it doesn’t appear to be the rest of the car.
Best eliminate it.
Post #617377 23rd Dec 2021 3:21pm
Caesium
Yours must have a different type to mine as bonnet closed is open circuit and bonnet up is circuit closed on my car.
I've simply disconnected the switch for now as that tells the car the bonnet is closed all the time. Thumbs Up Christian.
Current Cars
2019 BMW X4
or
Post #617381 23rd Dec 2021 3:35pm
Caesium
nicedayforit wrote:
Duracell AGM.
Best eliminate it.
I reckon it's an intermittent issue, I've got a 500 amp battery monitoring shunt on order so that will tell me (long term) if something is drawing down on the battery. Christian.
Current Cars
2019 BMW X4
or
Post #617382 23rd Dec 2021 3:37pm
Just a thought,
If the battery is indeed ok the one circuit your data logger didn’t record is the alarm system when the alarm is active.. When you tested l presume the alarm wasn’t operating. It’s quite possible that when the alarm operates for whatever reason it instigates a current drain on the alarm circuit which is sufficient to drain the battery over a longer period.
Can you disconnect the whole of the alarm system?
Post #617386 23rd Dec 2021 4:08pm
Caesium
That's a very good point.
Perhaps I'll repeat the testing when weather allows, with different test initiation criteria. Christian.
Current Cars
2019 BMW X4
or
Post #617390 23rd Dec 2021 4:31pm
SamThomas
United Kingdom 2003 Range Rover Vogue Td6 Baltic Blue
I don't think there is any singlepoint to do that as, AFAIK the alarm is interconnected with so many other things.
Good advice to charge the battery up & disconnect it to see what happens - I had a new Varta battery fail in less than 3 months sio it could still be the battery.
A tie wrap round the bonnet switch is as good a way as any to isolate it.
Post #617395 23rd Dec 2021 6:24pm
SamThomas
Post #617396 23rd Dec 2021 6:25pm
Pjtaroni
Have you checked for last alarm causes with a scanner?
Post #618092 31st Dec 2021 12:05am
Caesium
Rear doors both times, left and right. Christian.
Current Cars
2019 BMW X4
or
Post #618398 2nd Jan 2022 12:08pm
razmachaz
United Kingdom 2012 Range Rover Westminster TDV8 Santorini Black
I had the same issue. Rear doors apparently causing alarm to go off. Turned out to be the sun roof switch had been hit while cleaning and it was about 2mm down from sealed. Was causing the alarm about 15m after I locked or just left it open and it locked itself. Stopped doing it after I realised!
Post #618600 3rd Jan 2022 9:02pm
