![]() | Home > Wheels & Tyres > Who adjusts tyre pressures for ambient temp? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7881 ![]() ![]() ![]() |
Have read the below in the manual… 2011 L322, but imagine it applies to everything.
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 779 ![]() ![]() ![]() |
Pressure varies with temperature. If you read that piece carefully, it says that tyre pressures can be changed at the start of a journey, OR they can be adjusted on spec.
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1293 ![]() ![]() |
I wait for TPMS to tell me the tyre is low |
I’ve never adjusted tyre pressures for ambient temperature on any of my cars before.
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
Nope never done that. I just apply the pressure as per the label. Only adjust for the tyres i am running or the load I have. |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1396 ![]() ![]() ![]() |
It depends on where your car lives. If it is outside or in an unheated garage then it is just a case of maintaining the pressures at the recommended level for the car's load, whether you are towing etc. This is what happens to mine, though I will also check/adjust if the car feels wrong.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7977 ![]() ![]() ![]() |
As JMC points out - you shouldn't need to do anything special unless you are making an extreme journey.
any responsible car owner should check pressures weekly at outside ambient temperatures I.e before you drive - this will account for any seasonal changes. 2012 TDV8 Vogue (L322) |
Even in the days of having TPMS systems? Or do you count checking it on the TPMS as being responsible as well?
If you have TPMS then clearly no. Still worth doing a weekly visual check for wear, damage etc. 2012 TDV8 Vogue (L322) |
Thanks all. I clearly have misunderstood what it meant. Thought I might have, hence my query. They are back at the label pressures now. Much better 🤣
