Home > In Car Electronics (L405) > Ambient Lighting Not Working In Door Pocket
knwatkins
Hi guys, I noticed the other day that the ambient lighting in my nearside rear door pocket is not working. The door itself is still getting power as the actuator still works, the puddle light and door lock/unlock are still illuminated.
Anyone else had this problem?
I'll hopefully take a look over the next week or so and report back, but if anyone has any ideas, your advice would be greatly appreciated. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #617346 23rd Dec 2021 10:32am
bajeq
2017 Range Rover Vogue SE SDV8 Corris Grey
Dodgy Ambient Lighting
Hi, the ambient light around the front center console has stopped working in my '17RR. The front overhead/dome lights (left and right) don't work either. All the other interior lights work fine and the center light of the overhead console lights up when the door is open or at ignition shut off. Anyone else ever had this issue? Any advice would be welcome. Big Cry Question
Post #621024 23rd Jan 2022 12:55am
knwatkins
So, 6 months later, I've eventually got around to taking a look at this.
Door card removed...
The ambient light within the door card is generated by a single LED housed within a small black plastic connector. This LED shines light down an acrylic light pipe mounted within the door card that then diffuses the light within the door pocket.
On mine, the connector that houses the LED had become dislodged and was therefore not shining down the light pipe...
Fitted back in its place and it's now working as it should...
Hope this helps someone in the future should they have this issue. Kev
Post #634352 11th Jun 2022 3:53pm
Fiddly aren't they! Glad you got to the bottom of it sir Thumbs Up
Post #634382 12th Jun 2022 12:05am
Maher2023
United Kingdom 2018 Range Rover Autobiography SDV8 Fuji White
My Ambient Lighting, All door puddle lights and interior overhead welcome lights have all stopped working and maybe the AB tread plates as well..
I can operate all interior overhead lights manually but they don't work when you unlock car/turn engine off etc etc.
i have installed logo projection light about 2mths ago (not sure if they have anything to do with it)?
But on Saturday i remember leaving all doors open while i was cleaning the leather, so not sure if too much current have been draw by all lights and maybe fuse has popped?
Can someone tell me which fuse box & Fuse number(s) should i check for above issues? My car is MY18.
Thank you
Post #680615 18th Dec 2023 9:35am
Stick Legs
United Kingdom 2015 Range Rover Vogue SE SDV8 Causeway Grey
Thank you.
I have exactly the same problem, for 2 1/2 years!
If it had been the front I'd have attended to it but out of sight, out of mind!
I'll do this, be nice to fix something. Smile
Post #681597 31st Dec 2023 6:51pm
Maher2023
Hi Sorry forgot to update you. For some reason my Ambient lighting, interior & puddle lights all turned off went into ghost mode of some sort.
But interior lights and puddle lights were switched on by holding the middle interior light in overhead console for 2-3secs until you see a message on driver instrument panel.
And then ambient light was switched on from the ambient lights colour selection menu.
Post #681602 31st Dec 2023 7:33pm
