Yes the spring was exactly the same as yours. So that was the easy bit.
The big piece of trim was tricky to get back in place, and then of course had to come back off anyhow. I am going to use all new trim clips next for the best chance to get a snug fit.
I did clean the non return Valve, as i had heard they are problematic. I actually swapped it out for a spare Jag part I had though in the end, as the non return function seemed to stop working. I could blow air both ways through it.
I put a pin through the jets on the wiper arm too, but there’s still no liquid squirting out of there. So that needs more faffing next it seems. 2007 L322 TDV8 3.6 Vogue SE
2006 L322 S/C 4.2
2003 L322 TD6 Vogue with Facelift conversion
2000 Discovery 2 TD5 ES. Daily
1990 RRC 3.9 V8 LPG
Too many Jaguars!
