Home > Maintenance & Mods (L322) > Battery
Discofish
England 2003 Range Rover HSE Td6 Oslo Blue
Battery
Possibly a bit of a odd question but, how are your batteries fitted i.e. terminals towards the engine or facing the bulkhead?
mine is the latter and I'm finding it very difficult to get anywhere near the negative terminal as it seems to be permanently loose no matter how much I try to tighten it....
Post #617147 21st Dec 2021 4:55pm
On a TD6 the battery terminals are nearest the bulkhead. The negative terminal is definitely a bit intricate to fit, l tend to fit it before l clamp the battery down in position. Unclamped the battery can move quite a bit towards the engine.
If you can’t get the clamp tight are you sure it is down fully on the terminal or could it be it’s time for a new negative cable.
If the cable clamp is slack you could always do the piece of copper pipe wall down between the clamp and the terminal and then tighten trick. Thumbs Up
Post #617173 21st Dec 2021 7:35pm
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
My terminals are close to the bulkhead.
Post #617175 21st Dec 2021 7:40pm
RichM63
France 2006 Range Rover Vogue TDV8 Stornoway Grey
Towards bulkhead, 10mm pipe spanner.
I guess that it may be possible to replace the Batt with a version having the terminals LH+ve so that you could fit it the other way round?? L322 3.6 TDV8 Vogue. 07MY
ML 320 7 Seat full leather etc. (The Black Pearl) Wink
Post #617176 21st Dec 2021 7:40pm
Discofish
Cheers,
As it happens I decided to make up a new earth cable yesterday as had the bits lying around so just a case of now getting the time to actually get it fitted onto the car (apparently we are doing stuff this weekend for some unknow reason Wink so will have to rough it in a freezing cold discovery till then Big Cry )
Post #617220 22nd Dec 2021 9:01am
