![]() | Home > Maintenance & Mods (L322) > Transmission solenoid kit |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 806 ![]() ![]() ![]() |
Can someone confirm the part number for the Solenoid kit for the ZF HP26 in a 2007 TDV8. I am pretty sure the ZF kit number is 1068298044 but have been unable to confirm 100%
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1000 ![]() ![]() |
Yes, that’s the correct kit for the M-shift version of the 6HP26X used in the L322 i.e. 3 x yellow, 3 x blue & 1 x black.
Thanks for that RRPhil. Maybe you could answer another question about these solenoids. There seem to be many options to get refurbished ones along with new genuine ZF ones. In my case the gearbox is working fine, I know that it had a fluid change and new steel sump but not when. It has also had the latest software flashed recently at the dealers. I am planning to change the fluid and filter again along with the valve body sleeves and bush plus the mechatronic bridge seal. I can't afford a genuine set of new solenoids but was thinking to swap mine with a refurbished set while the valve body is out. Do you have any experience with refurbished solenoids, would you use them or just leave the old ones in. The car has done 130000 miles. 2007 TDV8 VSE
I personally don’t have any experience with refurbished solenoids. Page 14 of this Sonnax document : https://www.sonnax.com/tech_resources/423-...r-60sn-09d shows the internals of the EDS solenoid, once it has been cut open, and I’m struggling to imagine what exactly can be refurbished. Problems are generally caused by wear in the armature pin guide hole & its sealing face, as can be seen in this video by Richard Wardell :
Phil |
What a great video, I have recently watched many how to`s on the HP26 but no one has even attempted a teardown of the solenoids, only a resistance check. I will try to find out what is involved in the refurbishment, I just presumed new o rings, a clean and test that they are in spec and maybe new filter screens. If they also include new plastic caps with the brass bushing that the video shows wearing oval I might be tempted. A set is only A$150. Is it common for the dampers to be flattened/destroyed, I would not even consider splitting the valve block. 2007 TDV8 VSE
The EDS solenoids are the Achilles’ heel of the 6HP26/28, so it isn’t unusual for the dampers to be flattened. Sonnax produce a Zip Kit which replaces the rubber damper springs with steel helical springs, but I generally just replace them with new (rubber) ones.
The Mechatronic units are a joy to rebuild – you just need to be careful not to lose all the balls (check valves) when they fall out ![]()
Phil |
Goes without saying that the real fun starts when you painstakingly go through each individual hydraulic circuit and calculate the pressures required to actuate each of the spools. Who would be sad enough to do that?
Phil |
fanders Member Since: 10 Jul 2013 Location: Hants, UK Posts: 318 ![]() ![]() ![]() |
Fully approve of your approach RRPhil, in understanding the systems you work on at the design level. That is very rare in the automotive world, chapeau!
