Home > Maintenance & Mods (L322) > GAP IID tool - EGT reading
2010BlackL322
United Kingdom 2010 Range Rover Autobiography Black 4.4 V8 Santorini Black
All,
Can anyone tell me if the GAP tool will show EGT readings in real time through the app?
Thanks
Mark Check out my YouTube channel
https://youtu.be/UHBbLWZXw4A
Post #617000 20th Dec 2021 12:35pm
JayGee
AFAIK if there is a sensor then it will be readable and selectable as a live value. 2012 TDV8 Vogue (L322)
Post #617004 20th Dec 2021 12:52pm
Baltic Blue
EGT exhaust gas temperatures are available as live values for both banks as shown in my example screenshots.
I have got lioads more showing lots of different combinations.
Mike.
 G reg 2.5VM Vogue Portofino red 1991- 1999
Post #617005 20th Dec 2021 1:01pm
2010BlackL322
Thank you! Figured it would display them, but just wanted to check. Check out my YouTube channel
Post #617012 20th Dec 2021 1:55pm
2010BlackL322
Unnecessary quote removed
Thanks Mike,
Can you also see boost pressure, assume if you can see EGT’s then BP is available too?
Thanks again
Post #617026 20th Dec 2021 5:36pm
Baltic Blue
Do you mean exhaust manifold pressure ?
I will take a screenshot of all the engine live values for you tomorrow.
Post #617029 20th Dec 2021 6:00pm
2010BlackL322
Turbo boost pressure Check out my YouTube channel
Post #617030 20th Dec 2021 6:04pm
Baltic Blue
I have now taken screenshots of all the available Live values for the engine, but their are far too many to upload them all.
Is this what you wanted ?
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #617097 21st Dec 2021 12:10pm
2010BlackL322
Thank you! Check out my YouTube channel
Post #617102 21st Dec 2021 12:51pm
Baltic Blue
If you want to see the full list, you could PM me an email address and I will send them direct.
Post #617104 21st Dec 2021 12:59pm
2010BlackL322
Thanks, I have ordered one, I borrowed one when I bought mine to check error codes etc.
I’ll have a play when mine arrives to get the right gauges set-up on my iPad. The Defender has EGT and Boost gauges, as well as temp and oil pressure gauges, it was good to watch the gauges when driving, especially on long hill climbs, found it re-assuring to be honest when you saw the EGT’s shoot up.
Cheers
Thumbs Up Check out my YouTube channel
Post #617105 21st Dec 2021 1:06pm
