Home > Technical (L405) > Suspected oil cooler |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 768 |
It certainly could be Dean. To see if there's oil in your coolant, just pop the cap off and take a look inside. The coolant should be a nice red/pink colour. If it's dirty looking, you have contamination.
19th Dec 2021 8:46am |
deansmith Member Since: 17 Oct 2017 Location: Hertfordshire Posts: 88 |
Thank you very much!
19th Dec 2021 9:53am |
19th Dec 2021 10:16am |
Oil level showing as full but I think I need to get engine to temp then leave for 30mins for an accurate reading, is that right? |
19th Dec 2021 10:22am |
Officially yes, but it's still a good indication in a cold state. I'd be more concerned if it was showing it was over-filled.
19th Dec 2021 11:08am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4308 |
Which independent is busy until February?
19th Dec 2021 12:40pm |
The specialist is Woodside Garage in Maulden, Bedford. Incredibly knowledgable and they looked after my previous L322. They’re suffering with Covid related issues.
19th Dec 2021 12:45pm |
Update:
19th Dec 2021 12:52pm |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 873 |
Looks ok to me - I’ve had the oil cooler gaskets leak on a couple of previous 4.4 TDV8’s and both times the expansion tank was very obviously contaminated with oil, yours looks fine.
19th Dec 2021 12:56pm |
Oh brilliant, that sounds promising to me. Thank you for the reply!
19th Dec 2021 1:09pm |
Keep a close eye on the coolant level over the next few journeys (but always check the level once fully cold) & assuming it doesn’t noticeably drop you should be ok, although doesn’t explain the previously low level.
19th Dec 2021 1:20pm |
Landphil Member Since: 03 Oct 2016 Location: U.K. Posts: 119 |
I’ve just had this exact problem and it is the oil cooler gasket that seems to be the problem. I also had an EGR cooler gasket replaced as well.. Also an oil leak from the back of the engine that while you can see oil the oil level remains at full. A little oil goes a long way.
19th Dec 2021 2:39pm |
Quick update on this:
5th Jan 2022 7:33am |
Ukandrewf Member Since: 29 May 2013 Location: South bucks Posts: 240 |
interested to know who your warranty was with. I'm with Warranty Wise - they've agreed to pay to replace the oil cooler as faulty, which is good, but they only allowed 2.1 hours to do it when it's a 7-hour job. think they were looking at my old l322 details and not the l405 4.4 I have now. Hopefully it will get resolved today. But it's been six days without a car and because they only give a hire car for over 6 hours of labour I can't claim until they update the approval. they also didn't want to pay the few pounds for new gaskets but surely you can't reuse the old ones? I'm also having a problem with heating in the car where I need a new aux water pump, heater valve and thermostat. both will cost about £2,500 in total. Andrew -- On my third Full Fat RR |
8th Jan 2025 10:22am |
